@ColdCowboy - can you tell me what security setting you changed? I’m struggling with openLuup_getfiles as well.
When i run the test code in altui i get
[code]<?xml version="1.0" encoding="iso-8859-1"?>
404 - Not Found404 - Not Found
404 [/code]I can ping my Vera and get a reply inside openLuup, so I’m thinking i have some sort of security setting blocking it. I did change the firewall settings on my Vera Edge to allow all connections and the _getfiles utility still can’t connect to my Vera
openLuup_getfiles - utility to get device and icon files from remote Vera
Remote Vera IP: 192.168.1.162
lua: openLuup_getfiles.lua:55: error reading remote directory listing
stack traceback:
[C]: in function 'assert'
openLuup_getfiles.lua:55: in function 'get_directory'
openLuup_getfiles.lua:62: in function 'get_files_from'
openLuup_getfiles.lua:81: in main chunk
[C]: ?
