I’m trying to get the VeraBridge working but have been unsuccessful so far. I’m running Cudanet’s Debain server on VirtualBox and have been been able to see and control my Vera2 from AltUI but that’s it.
In following the openLuup user guide (section 5), I see that all the VeraBridge files are there on the server, but the guide doesn’t mention if I am supposed to edit any of those.
In section 6 of the user guide, I have tried running the openLuup_getfiles.lua code but get back the following error:
test@openluup:~/vera/cmh-ludl$ lua openLuup_getfiles.lua
openLuup_getfiles - utility to get device and icon files from remote Vera
Remote Vera IP: 10.0.0.60
lua: openLuup_getfiles.lua:55: error reading remote directory listing
stack traceback:
[C]: in function ‘assert’
openLuup_getfiles.lua:55: in function ‘get_directory’
openLuup_getfiles.lua:62: in function ‘get_files_from’
openLuup_getfiles.lua:81: in main chunk
[C]: ?
Needless to say i’m a noob with this stuff but keen to get this going as my Vera2 is pretty flaky. Any help would be much appreciated!
At the point where it fails, Vera should have a file [tt]/www/directory.txt[/tt] - are you able to ssh into it and see that, or see it with the HTTP request:
http://10.0.0.60/directory.txt
It’s the latter version which getfiles is trying to use, so I’m guessing that will fail, which actually means that the code to create it earlier has not succeeded. I’ve never had a Vera 2, so don’t know what the differences might be. This is UI5, or earlier ??
[quote=“akbooer, post:2, topic:192315”]What firmware version is your Vera 2 running?
It’s the latter version which getfiles is trying to use, so I’m guessing that will fail, which actually means that the code to create it earlier has not succeeded. I’ve never had a Vera 2, so don’t know what the differences might be. This is UI5, or earlier ??[/quote]
I believe it is UI5 although I’m not sure how to tell what version (if there are more specific version numberings).
Yes, i can ssh into the unit and see /www/cmh folder. And I have also attached the directory.txt file from the code above.
Oh, that’s interesting. So the code HAS produced a directory file AND you can retrieve it with a browser (or did you pull it from ssh) ? I wonder, then, why the update code cannot read it.Is the failure repeatable (I assume so) ?
If you haven’t tried the URL to access the file, give it a go.
If you haven’t tried the URL to access the file, give it a go.[/quote]
So I have the directory.txt file - is that all I’m looking for? What do I do with that file once I have it?
The point is simply that that file is what the ‘getfiles’ script uses to download the data from Vera. But for some reason, you’re telling me that the script fails, and yet the file is there.
You should be able to access the file via the URL I gave, and that it also what the script does. So if you can access it, the script should be able to. But something is clearly going wrong. Can you confirm that you’ve troied and succeeded viewing the file with that URL?
There’s no problem with manually downloading the files you want using the UI5 interface, but it’s a bit tedious.
[quote=“akbooer, post:6, topic:192315”]The point is simply that that file is what the ‘getfiles’ script uses to download the data from Vera. But for some reason, you’re telling me that the script fails, and yet the file is there.
There’s no problem with manually downloading the files you want using the UI5 interface, but it’s a bit tedious.[/quote]
So when I run the script, yes it fails with the error above. Every time. But when I used the “http://10.0.0.60/directory.txt”, yes, i was able to see that file.
And yes, i can connect via SSH to the Vera2.
Is the problem that the directory structure is different than your script is anticipating? Or you mention downloading the files - what is involved there? What files do I need?
All the script does at that point is use the same URL, so I’m a bit perplexed.
Can I see a console script of your run of openLuup_getfiles?
Did it successfully retrieve anything? Is your files directory empty?
Also, if you look at the script code at the end, then there is a commented out section for UI5. If you uncomment those and comment out the UI7 section then let’s see what happens. This would only affect retrieval of the icons, though…
[quote=“akbooer, post:8, topic:192315”]All the script does at that point is use the same URL, so I’m a bit perplexed.
Also, if you look at the script code at the end, then there is a commented out section for UI5. If you uncomment those and comment out the UI7 section then let’s see what happens. This would only affect retrieval of the icons, though…[/quote]
I’ve attached a console view of it and also tried changing to script to comment out the UI7 and comment in the UI5. No change. And no, no files have been added.
By files directory, i assume you mean /cmh-ludl/files and yes, this is empty. I can’t see anywhere else they might have been put.
[quote=“akbooer, post:12, topic:192315”]Truly bizarre. Try this piece of code (put into a file ‘test.lua’ and run with ‘lua test.lua’ in the unix shell.
local http = require "socket.http"
local info, status = http.request "http://10.0.0.60/directory.txt"
print (info, status)
I think it was as simple as having the security setting on the Vera switched off. I should have realized that sooner. Thanks for your patience though! I appreciate the help.
