Richard,
Hi, I am having a new issue. I had to start over with my Vera because it has a lot of garbage, so I clear my ZWave network and got back to factory settings and start over again. It was quick and now it is working very fast. The thing is that I don’t know why my Alerts with special characters ??? and ? are getting incorrectly. (Eg. Rec?ara when it should be Rec?mara). The thing is that if I send the alert via the device created, in the “Send Alert” tab, I get the correct alert, but when I send them through PLEG, I get the problem. Previous to restarting my network from scratch, it was working perfectly, but I can’t find a setting to switch that. Hope you can help.
Regards.
