I set up my Vera3 as my house router initially. After realizing it wasn’t going to do what I wanted, and it went into some weird funk where the web configuration screen always got an error, I decided to go back to my old house router setup.
Now I can’t get the Vera3 to work properly. I plugged the WAN port into my house LAN. That works, except that I can only reach the web config screens through cp.mios.com, not the house LAN IP. And the wifi and LAN of the Vera3 isn’t on my local network, but has its own network. So basically its 4 ports and wifi are useless.
I just did a “factory reset” and it appears to still be doing the same thing. I don’t know how to figure out its network since other than to click on “Manually configure” and look at what is there.
Is there a way to get it into the mode that it is not a router? The mode that it should be doing automatically, but isn’t.
I am sure this has been answered before, but I searched and looked and the Wiki and can’t figure out what to do. I’ve already wasted so much time on this device it is ridiculous. Not to mention the Captchas and all to just post are pretty ridiculous as well.
