I’m new to the forum and I’m sure this has been answered somewhere. I have ADT Pulse and don’t like how you are very limited to what you can ass to it. I’m looking at getting a Vera. I have a new wireless router that I am going to continue to use. My question is, do I buy the Vera3 or the Lite? I plan on setting up an extensive automation network.
It depends on how extensive… Your network of zwave devices and plugins gets.
It sounds like your planning on going big… So a vera 3 is not a bad choice.
But, if you have a large home, multiple vera lites may be a better idea … For zwave coverage.
Memory is the most precious resource on a Vera.
You can add a good number of Z-Wave devices to a Vera Lite. Z-Wave devices do not use much memory.
But if you use Plugins the memory starts to get used quickly. And there are a lot of useful plugins.
I would suggest that you get a Vera 3 … ignore the router … the memory is what you want! It has twice the memory as a Vera Lite.
[quote=“atmo377, post:1, topic:180213”]I’m new to the forum and I’m sure this has been answered somewhere. I have ADT Pulse and don’t like how you are very limited to what you can ass to it. I’m looking at getting a Vera. I have a new wireless router that I am going to continue to use. My question is, do I buy the Vera3 or the Lite? I plan on setting up an extensive automation network.
Sent from my iPad using Tapatalk[/quote]
I know this sounds bit off topic. But you may want to hold off buying a Vera at this time because new line of Vera Controllers with UI6 is about to be pushed to the market. Check this link, Micasaverde présente ses nouvelles Veras - Blog Domadoo
[quote=“geotech”][quote=“atmo377, post:1, topic:180213”]I’m new to the forum and I’m sure this has been answered somewhere. I have ADT Pulse and don’t like how you are very limited to what you can ass to it. I’m looking at getting a Vera. I have a new wireless router that I am going to continue to use. My question is, do I buy the Vera3 or the Lite? I plan on setting up an extensive automation network.
I know this sounds bit off topic. But you may want to hold off buying a Vera at this time because new line of Vera Controllers with UI6 is about to be pushed to the market. Check this link, http://blog.domadoo.fr/2013/01/09/micasaverde-presente-ses-nouvelles-veras/[/quote]
That is from over a year ago. No new controllers have been announced.
Thanks for the info. I’m going to order the 3.
