Vera3 UI5 and AD2USB
I am on the final step to configuring vera3 and AD2USB and I was configuring the serial port when I got this message when trying to change the baud rate to 115200.
Save data
This feature is not enabled. You need to upgrade to the ‘Professional Home Automation’ option
Vera3 will not allow me to save the change…why?
Oh and what is Professional Home Automation…
I started getting that message over and over so I rebooted vera3 and that solved the problem.
