Vera3 Died
Hello everyone,
My Vera3 just died, it as working fine than I stepped out of house to get something and when came back it was dead. No lights whatsoever, Tried using different power port, different power cable but the result was unchanged.
Then I called my supplier and he said it has happened only second time in last two years and he is happy to replace the unit. Replacing the unit may solve the issue but the question is how would I trust Vera again if it just goes blank out of nowhere.
Has it ever happened to anyone?
Devang
Electronics fail. It is the fact of life. I would not worry so much. I’ve owned my Vera 3 for several years now and it has not caused any hardware issues.
  • Garrett
[quote=“garrettwp, post:2, topic:182241”]Electronics fail. It is the fact of life. I would not worry so much. I’ve owned my Vera 3 for several years now and it has not caused any hardware issues.
  • Garrett[/quote]
Hi
I have had my Vera 3 installed in vacation property for the past several years. Despite frequent thunderstorms, and power outages (which are more severe and frequent at the beach) I have never had any problems. It just keeps on running…
Don
Your relationship with Vera is based on trust and that trust has been broken. You can never trust her again! The betrayal and mistrust will eat at you forever. You must make a clean break and vow never to use Vera again.
If you want to get even, try establishing a relationship with her sister or best friend.
…What?
…What?[/quote]
:slight_smile:
Over-reacting? :cry:
