Vera2 set as WiFi client and locked
I have only wireless internet access available currently and thus I was trying to setup vera 2 in WiFi client mode. It seemed it worked first but after restarting only the power button lights up - both z-wave and ETH1 LEDs are turned off. However if I plug cable to LAN port PC gets connected to network - so WiFi bridge seems to work. However I can’t connect to Vera UI anymore.
What are the steps to reset network settings and start over?
I am having the exact same problem. My Wireless Client mode worked fine until recently. It failed after I installed the last firmware and upgraded to version 1.5.622. It appears to be a problem in this version of the firmware. I emailed support but no one responded with an answer.
I had to plug my unit into my network and quit using the Wireless Client mode.
If you plug a PC or any other Ethernet device into the WAN port, the wireless client mode will start working. As soon as you unplug the device from the WAN port, it stops working. As long as the WAN port is linked up with any Ethernet device plugged into it, the Wireless Client mode will work. This is a work around if you want to plug any Ethernet device into the WAN port.
