Vera2 seems to be DOA
I have a new setup I am trying to accomplish. I cannot get the lights to light up as they should according to the website. My eth1 is not lit but my eth2 is lit. The service light is also lit up. A hard reset does not work, with two quick press’s of the reset button. The network connection is good as I can get a DHCP address from the router. I think that I have a bad box, would you agree?
If I assign myself an IP in the correct range I cannot connect to the default web page of the vera box because it thinks that there is no network connection when plugged into eth2. I knew that I should have tested this before I went down to my rental property 1900 miles away to get this setup. That is what I get for thinking.
Well I will reply to my own post. It is dead. Sent back in for a refund. Ordered vera 3 and that works great so far
Did you get it from MCV?
I actually got it from amazon.
It’s good thing they took it back for a refund!
