Hi guys, sorry for digging out the old topic on how to reset the vera2.
So here is what happened:
I have my Vera operational for about 2 years now. In the last 3 months it lost network connection 3-4 Times. When I unplugged the power cord and booted back up, everything was back to normal.
Suddenly this doenst help anymore. Here is a pic of the LEDs, nothing flashes, everything stays frozen.
I read the forum and found some topic, where someone stated he could fix the same state my Vera2 is in, by reflashing the firmware (cant find it anymore ).
Some other guy wanted to reflash and couldnt manage to get it done. I have the same problem. His final question about “if vera2 should respond to pings when in blinky reflash mode” has not been answered.
Here is what I experienced:
I am running windows 8 everywhere now. Have installed tftp, downloaded the tool and the bin file. When I set up my network connection as explained here. But windows keeps telling me “unidentified network” which means that my IP is wrong (as far as I read on the net). The vera2 is not pingable.
Can anyone tell me how to flash the device again? When I do the “power on with pressed button for 5 seconds” it’s doing the faint blinky thing with the power LED (suppose its a dimm additional LED) but I can’t use the upgrade tool.
The “Detect LAN Cards” Dialog is empty and clicking on “browse” → “browse targets” gives me a broadcast error.
Please help! I’d be so glad if I could get my vera up and running again.
Btw, if flashing is possible by using connectors directly on the board and a serial interface: I am equiped well, so any hints on how I could get it back to life again would be appreciated.
With Windows 7 (32bit), I always had to also run the .exe in XP compatibility mode. Its also key to make sure you are plugged into eth2 port (easily missed).
Nothing working anymore at all? I had dead vera2 all the time and repaired it with using the external USB disk for logging. No problems anymore. But yes, if can’t even get into it anymore you have nothing with this post.
Nothing… attaching a USB disc didn’t help either. It’s dead… gets nailed to the wall next to my PS3.
I guess nobody will help me flashing the thing with some onboard connectors… Makes me sad, but I have to say that this has then been the last Vera in my home. Since RPi gives me a much cheaper solution and I am quite dissappointed by the liftime the Vera2 had.
I have no problem investing a ton of time in fixing this thing, but none of my tries did show any success and I am clueless… :‘( :’( :‘( :’( :‘( :’( :‘( :’( :‘( :’( :‘( :’( So I’ll invest a ton of time in a RPi solution which can always be fixed with ~30$.
