I am looking for help on how to get my Vera2 to keep its setting after it has been rebooted. I have tried saving it both in the main menu and in the advanced menu. I have also made a good back up and have been able to use it several times with the correct settings. Unfortunately; every time I restore Vera2 from back up I have to go through the process 3-4 times before it will remain the way it has been set up. More often than not it will revert back to the default SID and Default IP address. When I am successful in changing the settings the new settings will last only two to seven days before returning to default again. Any suggestions??? This is getting frustrating.
Side note: It did work for about 3 months without any errors and when it logged into mios.com for a update this is when the problem started.
