[quote=“intveltr”]The Hue plugin mostly works; the clickable color map doesn’t react to clicks.
The HomeWave app works (at least the basic funtions and remote access), including the HomeWave Push plugin.[/quote]
Not working at my just Got a new hue hub. Can not connect.
[quote=“bwilli001”]So far these are working for me.
[ul][li]Honeywell Ademco Vista Alarm Panels via AD2USB[/li]
[li]Smart Switch Plugin[/li][/ul]
What doesn’t work which is documented is AutHomationHD[/quote]
Smart switch didn’t work for me. The settings tab returns an error, which does not allow for you to set the trigger. Please let me know if you are having a different experience.
[quote=“garrettwp, post:23, topic:182371”]AutHomationHD should work as long as you are using the beta version.
Garrett[/quote]
I’m using 3.3.1.1 and locally it works as long as you don’t look at the current status of the device you’re manipulating. Example: light shows on in app, physically it’s off and you use AutHomationHD and it turns light on.
Also I keep receiving an error on refresh “Received invalid json responses” I suspect this is the reason for the issues that I have just described. I will be reading through the discussion on AuthomationHD link later today to see if it’s a setting I have to correct.
[quote=“bwilli001”][quote=“garrettwp, post:23, topic:182371”]AutHomationHD should work as long as you are using the beta version.
Garrett[/quote]
Also I keep receiving an error on refresh “Received invalid json responses” I suspect this is the reason for the issues that I have just described. I will be reading through the discussion on AuthomationHD link later today to see if it’s a setting I have to correct.[/quote]
You are running an old beta. Please update to the latest version.
I updated to 3.3.1.4 Hoping that is the most current.
Still receiving the error message “invalid json responses” when trying to remote in and refreshing the screen.[/quote]
Make sure that your vera connection details for Primary and Backup server point to vera-us-oem-relay11.mios.com and vera-us-oem-relay12.mios.com. The active server should be one of these depending on which server your Vera is using.
