I am looking for a way to create a low power temporary button push for multiple devices. I’ve searched the boards, but have not been able to find anything yet.
Basically what I am trying to do is fashion a device that can control my alarm system and garage door opener. I have an older alarm system that isn’t wifi or z-wave compatible. Previously I used a GE outdoor module connected to a relay with a fuse which was wired to the contacts of a garage door remote. I created an event which temporarily closes the switch, pauses then opens the switch. This was a couple years ago and seemed like the only option at the time, even if it was overkill.
Now I want to do something similar with the other garage door and a remote fob to turn on/off my security system. I’m comfortable with soldering and stuff of that nature (see original solution), but it seems like it is too much equipment for what I’m trying to do. I know there are arudino shields that have multiple relays for low power. Is there anything like this that I could use for what I’m trying to do?
