vera support on palm pre
i’ve just setup my vera and one of the main things I want to do is check on my house via my palm pre. But the UI appears to require a flash plug in that isn’t supported on the pre (yet).
Is there a moble version of findvera.com that is lighter, fits on a small screen and doesn’t need plugins?
You have to install the smartphone plugin in the MIOS plugin area; after that you should be able to go to findvera.com/mobile
The SmartPhone plugin works great.
Compact enough to be able to read and control stuff without having to constantly zoom in/out.
Glad you got it working!
