Vera SLOOOOOW after removing PLEG/PLC
Vera2 UI5.
I removed all PLEG devices on DEVICES page then removed PLEG on APPS page then removed PLC. Then I went in SSH and removed Program* and ?_Program* from /etc/cmh-ludl then I removed Program* from /www/cmh/skins/default/icons (they were links to the icons).
Now my Vera is extremely slow. Using vi to look at the log (over SSH) can take 15-20s to finally show. Top sometimes shows low numbers for CPU use and high idle (.3, .3, .3, 70%) and sometimes shows pathetic (4.5, 4.5, 4.5, 30%). Doesn’t really tell me much.
Any ideas??
Shoulda mentioned that the (USB) log is quite large (88,000 lines) though I don’t see anything odd.
Is there a way to force a rollover of the logs to eliminate that possibility?
