just got new vera 2 arrived in post set up ok still waiting for new z wave products so i powered it off . when i powered it on again to familiarize my self with mios it wont let me log in i am a newbe to all this. eth1 port keeps flashing i and cannot find vera on my home network any clues thanks
Hmmm, I have had this happen a few times in the past. How long do you let it sit before trying to connect to vera? Do you have it configured so that it gets an IP address from your router (DHCP)? Can you log into your router and see if it is assigning an ip address to the unit? Try power cycling the unit. If and when you can get to the unit, you may want to setup a static ip to the unit so that you always know the exact ip address for Vera.
- Garrett
wow working thanks
