Hi, I have just had installed blinds. Somfy could not be used due to size limitations so the firm have used Rullo. Looks very good and I am assured will work with the RFXtrx433e. However, Rullo is not listed on any of the protocol / driver files. I have updated with all latest files from Vesternet. There seems to be no support for Rullo. Can anyone help?
You might try plugging the RFXCom device into a PC and have it listen with different protocols checked while you press buttons on the remote, looking for output from the transceiver on the screen. I was able to find a protocol that recognized my remote commands, but it wouldn’t operate the motor I have due to small differences in the protocol. But if your motor is supported already then you might be able to control it once you identify the correct protocol?
the manufacturer of the motor shown in the Rollu website does not appear in the list supported by RFXcom
for more details contact:
info@zwavemotors.com
