I have a Raspberry Pi with a temp sensor DS18B20 connected. Can I some how read the value on the temp sensor and present it in vera?
Can you use the Luup request: variableset ?
http://wiki.micasaverde.com/index.php/Luup_Requests#variableset
I’ve not tried this by the way. You would need to make an HTTP request on the RPi to set the variable would then be able to access is on the Vera using local Luup code, e.g. in a scene.
Rob
The answer was in this thread
http://forum.micasaverde.com/index.php/topic,17986.msg158305.html#msg158305
works great!
