I have several newly added Qubino DIM (ZMNHSD1) and mini(ZMNHHD1) dimmers that after a few days will stop responding to commands (on/off/dim) from the Vera controller. The logs show a message can’t encrypt. Oddly when I turn the switch on manually, the status and wattage are properly updated on the Vera. Re-including and factory reset do not solve the problem.
Any suggestions?
08 | 03/21/22 12:32:07.446 | JobHandler_LuaUPnP::HandleActionRequest device: 91 service: urn:upnp-org:serviceId:SwitchPower1 action: SetTarget <0x6f813520> |
08 | 03/21/22 12:32:07.446 | JobHandler_LuaUPnP::HandleActionRequest argument DeviceNum=91 <0x6f813520> |
08 | 03/21/22 12:32:07.447 | JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:upnp-org:serviceId:SwitchPower1 <0x6f813520> |
08 | 03/21/22 12:32:07.447 | JobHandler_LuaUPnP::HandleActionRequest argument action=SetTarget <0x6f813520> |
08 | 03/21/22 12:32:07.447 | JobHandler_LuaUPnP::HandleActionRequest argument newTargetValue=1 <0x6f813520> |
08 | 03/21/22 12:32:07.447 | JobHandler_LuaUPnP::HandleActionRequest argument rand=0.018034494077427188 <0x6f813520> |
02 | 03/21/22 12:32:07.448 | JobHandler_LuaUPnP::ConfirmGlobalActionRules replaced binary on with dim 40 <0x6f813520> |
06 | 03/21/22 12:32:07.448 | Device_Variable::m_szValue_set device: 91 service: urn:upnp-org:serviceId:Dimming1 variable: LoadLevelTarget was: 40 now: 40 #hooks: 0 upnp: 0 skip: 0 v:0xbefb40/NONE duplicate:1 <0x6f813520> |
02 | 03/21/22 12:32:18.566 | ZWaveSerial::GetFrame 0x764c0844 timed out now 0 m_listGetFramePending 0 <0x764c1520> |
01 | 03/21/22 12:32:18.566 | ZWaveNode::GetNonce node 45 failed (nil) <0x764c1520> |
01 | 03/21/22 12:32:18.567 | ZWaveNode::EncryptFrame m_iFrameID 267638 cannot get nonce node 45 command class 0x26 command 0x1 <0x764c1520> |
02 | 03/21/22 12:32:18.567 | ZWaveSerial::Send m_iFrameID 267638 type 0x0 command 0x13 sent ok - can’t encrypt <0x764c1520> |
01 | 03/21/22 12:32:18.567 | ZWJob_SendData::Run done/fail job job#10392 :Level 40 node 45 dev:91 (0x233c128) N:45 P:35 S:7 Id: 10392 took 11117 ms method 2 to node 45 command 38/1 failed 5 retries 0 of 5 <0x764c1520> |
Cheers Rene
