I previously had LC12s and had the panic mode issue with an old vera lite. Im thinking of getting some LC13s which apparently did not have the same issues with Panic mode. Can someone confirm if these devices work with the Vera Plus? Thanks.
For what it’s worth
I have two POPP TRVs (POPE010101) that are DANFOSS LC13 with a modified firmware (reports the temperature from the internal sensor). Vera Identifies the Manufacturer as Danfoss.
They work fine with a Vera Secure, I have been using vera FW 7.31 since it was released, and I upgraded to 7.32 Beta 4 a short while ago.
