Vera Log Files: How to access?
Newbie, attempting to explore the VERA-2.
How can I browse the directory structure in the Vera? I want to understand the structure, inspect log files and generally satisfy my curiosity. I’ve configured Vera to write log files to USB thumb drive. I assume this is where I need to look for log files, correct? If so, what is the path? /tmp/log/cmh?
I’ve browsed about with Putty. Does Vera support FTP server? If not, what options are available to make open the directories to my Win7 desktop?
Finally…
I’m a newbie to Vera/zWave but otherwise fairly experienced inthe WinTel environment with a bit of coding experience. I ASSUME inspecting files is low risk and modifying or deleting could brick the system.
Is this correct?
Is there any specific warnings to “stay-away” from certain internals of Vera?
Thanks much.
You can use winscp to browse the files on vera. To view logs via the web browser you can use this url: http://veraip/cgi-bin/cmh/log.sh?Device=LuaUPnP.
I would be careful when poking around.
  • Garrett
Thanks MUCH for the quick reply.
I installed the WinSCP. Logged in as root with password on bottom of vera. Says access is denied.
Any suggestions?
2nd unrelated question:
I see zWave inventory at bottom of many postings. I can’t see how to add my own. Is there a profile property whereby I can add my inventory?
Oh, since you are so generous with your time…
What defines a “newbie” on this forum?
How do you graduate out of that status?
Thanks!
Phil
In winscp, set file protocol to Scott and make site port number is set to 22.
  • Garrett
Will this only work if I am local to the network with the Vera connected?
Is there a way to view logs remotely?
Will this only work if I am local to the network with the Vera connected? Is there a way to view logs remotely?
You could forward port 22 to Vera's IP.
JOD.
