Vera Lite UI5 - All devices not working
Hi All - I have a medium size home Z Wave network that for no apparent reason stopped working. After devices quit responding to commands sent through my Droid phone, I logged into Micasaverde and discovered about 100 new devices - all names _Generic IO. All my “real” devices had the error “Device failed to configure” in a red band at the bottom of the device. I restored a good backup of a couple of weeks ago and all of the _Generic IO devices disappeared, however all of my actual devices still had the failed to configure error. After a network heal that took 2 days, there is no improvement. Still cannot get any devices to poll or configure.
Any suggestions? Thanks in advance.
Can you or did you restore the the Z-Wave network as well as Vera?
If that doesn’t work, I’d try excluding then including a/any device, to see if Vera works at all. It sounds like your Z-Wave “dongle” may be bad.
