Is there a way to get access to the full log file on the Vera Lite please? >:(
I can SSH into the device using Putty but when I try to use the FileZilla client, it won’t let me connect.
I’ve had two random issues with the VeraLite this month when devices have just come on when they shouldn’t do and I’d like to look at the logs to see what’s going on. Why have they made it so hard to get acess to the complete log file. I know I can ‘tail’ is using a web browser but that’s no good for older entries.
Opening the log file in your browser(http://[your local ip]/cgi-bin/cmh/log.sh?Device=LuaUPnP). If you are using a windows computer, you can use “Control A” to select all the text. Then use “Control C” to copy the text. Then open Notepad and paste the text there, where you can move around the text without any problems.
Yup, that was it. It worked fine in IE but not in Firebox. Very odd, as the URL was the same, and the message I got was definitely from Vera, not a URL issue such as a 404 error.
