Vera Lite after UI7 update : questions
Hello,
For add recent sensor I updated my vera lite avec the last firmware UI7 (1.7.583)
Since this update I have 2 problems:
  • Impossible to connect with external internet access (http://cp.mios.com/ or ImperiHome application): a page with the old interface (UI5) is displayed with this message (in French for me, translated for you : impossible to communicate with your unit).
    With local access : no problem.
    Do you know how to solve this problem?
  • With the local access when I want to change a setting, the interface ask me my user and my password (normal for the moment). But when a validate with ?login? button, the interface always returns on the Dashboard page.
    → Impossible to change any parameter :cry:
    (I try with internet explorer, firefox, chrome)
    Thank you for your help.
Before my previous firmaware was UI5 : no problem with external internet access http://cp.mios.com/ and all setting page in the interface
You should search the forum as this is a well documented issue. The login server has changed with UI7… use http://home.getvera.com AND create a new user account
Thanks LV999 for your response, after creating a new account on http://home.getvera.com my systems work perfectly.
