Well, some more searching led me to the answer… It doesn’t work well.
I can make it work by manually changing the capability variable (remove 38:2), but as others have noted the “38” gets added right back if someone manually turns the switch on/off via the physical button.
I also saw reference to some beta firmware for the SS6, but can’t find it anywhere. Anyone have that?
I got almost the same issue, my aeontec smart swith would work with the physical swithch, the button on itself, via z wave device, however it would not change staus if activated physicaly any workaround this ? is it defective?
