Vera Light Automatic Polling Question - confused
Hi everyone,
Hopefully someone can shine some light into this.
I have one CT30 thermostat and two Kwikset Z-wave doorlocks.
I currentyly use Luup Code (and the Scheduler) to poll the devices.
I diabled the automatic polling option in Vera.
While this type of polling works absolutely great I wonder while Vera is not able to poll my devices automatically.
When I turn on the auto polling otion (and disable the Luup polling code), polling works fine for a couple of hours but then suddenly stops without any warnings. It feels like Vera simply “forgets” to poll my devices? There is absolutely no activity in the logs anymore after a while as well.
Does anyone experience the same issue?
As I said before, my system works fine (on the latest firmware) with the semi automatic polling via Luup - however I am just wondering if I really have to write a polling code via Luup for each and every device when Vera should handle this… ::slight_smile:
Anyways, thanks in advance for your answers and keep up the good work. :smiley:
Flo
@frichter09
Could this be related to how Vera is handling battery powered devices? Does your luup polling kill the batteries faster? Is your CT-30 battery powered ?
[quote=“aschwalb, post:2, topic:171036”]@frichter09
Could this be related to how Vera is handling battery powered devices? Does your luup polling kill the batteries faster? Is your CT-30 battery powered ?[/quote]
Hi aschwalb,
The CT30 is not battery powered. Sorry forgot to mention that.
I am polling the Locks once every 60 minutes - I have not observed any significant battery loss after 2 months - both @90%.
Florian
