Now I can see the vera at the google association. But I still cannot control the devices. My google assistant (Nexus 5x) does not understand the “talk to vera concierge”, it openes a web search. Could this be related to my german google account?
You should have seen the screen as displayed in: http://forum.micasaverde.com/index.php/topic,48893.0.html
So there might also be an issue with your Account … is your phone setup as German or English-US which I believe is required for Google Assistant for now.
I live in Toronto and I have a Google Home device and can’t seem to get it working with Concierge.
I’m able to “talk” to Vera Concierge but the response I get is “Problem getting configuration information for your Vera name XYZ”
My Google Home app version on my Android device is 1.24.33.6
I’ve changed my language to US English
I’ve successfully executed the jar on a headless Ubuntu 16.04 and can access the Vera Concierge Local Server Configuration on port 8989. I’ve entered my Vera credentials and can see my controller listed. I don’t, however, see my GH device listed in the Google Cast Devices section.
I don’t see “Assistant Apps” in the “More Settings” section… is that my issue? Is there any way around this if this is a Canadian restriction?
