Make sense?
C
Make sense?
C
So Iāll post this here, but not sure itās completely the correct place. Letās see.
This evening has been interesting. Started when I noticed that two of my Fibaro connected temp sensors had dropped out. I figured Iād do a restore from just before they failed.
So I did just that thing. Only to be met with a dead box.
All the lights are on.
SSH works
Odd
Reboot. Power comes on. Then nothing. More nothing, then all the lights come on at the same time.
Odd still.
SSH, no interface. Controller is off line
Much discussion with one of the guys on the helpdesk and we unplug the extroot SSD
Controller comes back as it was in February (just before the extroot)
Long story short, every time I plug the SSD back in, all sorts of weird shit happens. Including the LAN light on the connected switch going offā¦
SSD is fine in my Mac, so re-initialised. Still makes all the lights go mad.
I can only assume itās failed in some way. Any thoughts?
Cheers
C
SSDs can be power hungry so perhaps the one you are using exceeds the Veraās available USB current. If so, then the SSD will not operate correctly and cause USB port interruptions. Try attaching the SSD to a USB powered hub connected to the Vera or a lower-power SSD.
SSH still worked? This is very strange. If the vera failed to boot, then I would have suspected a power issue but it seems to have booted fine. If upon reboot it did not come back, then it is likely that somehow the extroot itself failed. But the first failure makes me suspect an error in the USB communication which may in turn have caused a corruption of the fstab. If you could post your fstab config, maybe I could take a look.
This is a good shout, although itās been fine for a couple of months.
Lua would not start. Iāve going to try some other USB devices and controllers see if it is the SSD or the controller for that.
But I think I may be in a bit of a halfway house and not sure how to get out. I seem to be missing lots of log files, for example I only have three logs in /var/log/cmh (LuauPnP, InternetOK and NetworkMonitor.
When we did a factory reset with the SSD in, it didnāt work. No power light, but everything else on. Hard reboot brought it back to SSH only.
Removing the SSD and power cycling again took it back to what looks like a Feb set up, just before I extrooted it.
Iāve restored back to late March (when all my sensors were working) but theyāre still not and as I say, I suspect Iāve lost some files in there somewhere.
I guess the sensible thing now:
Or is there a simpler way?
TIA!
C
OK just plugged in a USB stick and re-enabled USB logging. /var/log/cmh looks rather more healthy now, but still not sure itās complete?
-rw-rār-- 1 root root 257 Apr 8 18:11 InternetOk.log
-rw-rār-- 1 root root 241804 Apr 8 18:18 LuaUPnP.log
-rw-rār-- 1 root root 45001 Apr 8 18:19 NetworkMonitor.log
drwx------ 2 root root 12288 Apr 8 18:09 lost+found
-rw-rār-- 1 root root 2128 Apr 8 18:11 serproxy.log
Looks like it may well be the SSD or the cable. Thatāll be fun checking
C
Talking to myself and the future Feeling relaxed turned off the USB logging and plugged the SSD back in on the same controller cable.
Boom
Waited for everything to come back and then used a different cable.
All is well and Iām back extrooted.
So odd things are afoot with my other controller cable. Still works fine with a laptop, though. Shrug.
For some reason my logrotation and servers have not been restored but there we are
C
How do we increase ram file after extroot ?
The vera has no ram fileā¦
^^ this is what im talking about
was it this
Ohhā¦ I see yeah you can create a āswapfileā. It is pretty simple to do. You can go to the fstab and get it started from there. I have not had to do since I donāt have any RAM problem.
not sure if i have a memory problem here but even though my vera doent reboot the luup engine restarts
i have a lot of apps running
This looks like you have a memory leak and a rather fast one. I would address it first. Adding more memory is only going to delay the crash, not eliminate it. Unless you see it stabilize at some pointā¦ I am not seeing it from your data.
great point ā¦ where do i start with this memory leak thing:slightly_smiling_face:
The brute force way is to either:
Unfortunately, since the plugins all run within the LuaUPnP process, there is not other way to break them down and see how much each one is using at the OS level.
What is the red line? The sawtooth pattern suggests that it is related to the log rotate function and you can see that the frequency of the rotation increases over time. Is it the free memory?
It may be useful if you posted a list of the plugins you have installed. Some may be recognized as troublesome. Thereās lots of history and tribal knowledge there.
Global Cache GC100
Details
Virtual Outdoor Temperature Plugin (by MiOS)
Details
Amazon Alexa Helper
Details
Virtual ON/OFF Switches
Details
Push Notification
Details
Blue Iris Camera Plugin
Details
HouseModes Plugin
Details
System Monitor
Details
OpenSprinkler
Details
SiteSensor
Sercomm IP Camera
Details
Broadlink Vera Concierge
Details
Virtual Clock
Details
MultiSwitch
Details
Combination Switch
Details
Denon Receiver Control Plugin
Details
Garage Door
Details
Philips Hue ALTHue plugin
Details
VeraAlerts
Details
Kodi Remote
Details
Day or Night
Details
Reactor
Details
Radio Thermostat Wi-Fi Plugin
Details
VeraSecure
Details
Ping Sensor
Details
LuaView
Details
AutoVera
Details
ALTUI
Details
ERGY Plugin
Details
Switchboard
Details
Wake-on-LAN
Details
Well, I believe the Ergy plugin has a long history of suspicion. See thread Ergy? - Power Management - Ezlo Community
Agree 100%. I removed it from my system years ago due to a variety of problems.
Wow, thatās a long list. Some have very similar functionalitiesā¦ Are you stress testing the vera? Ergy would be my prime suspect as well. Not sure what the VeraSecure is. Are you making use of all of them?
Ā© 2024 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
