nice ill give it a go soon
From here thereon I will be posting the extroot scripts on github:
Will also be editing the first post to add this.
Iāve previously upgraded to 1.7.4833 (7.30) using your (earlier) script, I guess the one that didnāt upgrade the kernel.
So are all these steps required (especially the unplugging of SSD part), or would it be enough to do Vera firmware upgrade and run the new script? Also, are all these steps required in every (future) upgrade going forward?
It is better to do this:
- backup
- remove ssd and reboot
- upgrade to 7.31 (with factory reset option)
- extroot with the new script
- restore your backup
Want to make sure that you are not upgrading the ssd but the veraās internal drive.
I updated my Vera Secure (that was extrooted) with the ssd connected. After the update I had to run the script once again. That worked just fine. Back on track. So in my case the connected ssd didnāt cause any problems.
Since I extrooted my Vera, it seem to be much more reliable, faster and almost without glitches (which was common before the extroot). So Iām very greatful for all the support you @rafale77 and @rigpapa has provided us. Without the two of you, I and a lot more people would be long gone by now. So I just want to thank you both for staying, putting in the time and energy without being on Veras payroll. Thatās just phenomenal! Have a great day! Over and out. /Fanan
maybe ill test this one
By now, Iām sure all of you heard that @rafale77 was permanently banned from the Forum. Find him over on http://SmartHome.community these days.
Due to a failure of the onboard z-wave chip - Iām having to run one of my VeraPlus controllers with an external usb z-wave one.
Iām guessing not many people are doing that, but with that said - does anyone anticipated any problems extrootāing my Vera ?
External UZBā¦No problems.
It opens up a whole new world being able to use an external device, some improvements are:
- Less noise from the board.
- Better radiation pattern
- Allows use of a powered USB to improve power output.
- Simple to configure.
Xārooting is another problem left to the experts.
Hi
Many thanks for responding, my question was actually more around having an external USB zwave controller and adding an external SSD (via USB) to do the exrooting ?
Will that combo create any issues ? Im obviously going to need a USB hub to do it etc ?
Also regarding ā¦
Are you suggesting exrooting a Vera is not an easy thing to do ?
Everything is easy second time around. Iāve never done it so I canāt comment.
The experts who are best able to answer your questions have been banned from the forum.
They use different COM Ports so there wonāt be any foreseeable problems. You will need a powered USB Hub for best results and be prepared to play around with the Port settings if it doesnāt work first time.
edit: Iām not sure how you edit the config file in Vera, if itās like a RasPi then itās straightforward. As wrote above the people who can help you arenāt welcome on this forum and you need to search elsewhere.
