Vera Egde - Temperature graph and logging security devices
I moved (and moved back :-[) from Domoticz to Vera Edge. And where in Domoiticz each Temperature module generates very nice graphs (enclosed), I can not figure out how to achieve that on the Vera Egde.
Same for Security and Energy modules, I need logs and power consumption/production graphs.
The only thing I can see are current values.
I’m aware that usb is not working on the Vera Edge (contacted support more than a week ago).
Thanks for the help
It depends a little on what temperature sensors you are using… regrettably, Vera’s implementation of temperature only supports integer values for Z-Wave devices. However, with other sensors (such as the Weather app, or Netatmo) then fractional values can be shown.
Whatever the temperature device, a separate app is really needed to store and plot the readings. A popular choice used to be Datamine, but this is no longer supported. An alternative, albeit in beta testing, is DataYours. An example attached below.
