Vera edge - USB flash drive: maximum size?
says it all: is there a maximum size for flash drives to be connected to a Vera edge?
I’ve had a 16GB drive running and (as I must admit: rather roughly) swapped that
against a 32GB model. Now in “Datamine”, the total disk space is reported as 9600 kb.
Is this due to my probably wrong way of changing the drive? Or as I asked due to
a maximum disk size?
If it’s my fault :wink: : how can I make Vera to recognize the drive with its correct size?
Thanks,
Christoph
