ok - so the Edge plus is ordered and will be here soonish hopefully but just wondering what the general consensus id about what to do with the vera2 which is literally on its knees with the load i put on it.
I run quite a few various plugins and circa 25 physical devices and a number of virtuals.
house isn’t big enough to “need” two vera’s on different floors and my first thought is just to migrate the lot to the vera plus but wondering if its worth utilising both in some way
I’m pretty sure you can connect two controllers as primary and secondary and they will communicate with each other.
I actually had the same thought. I was considering using one controller for Z-Wave and moving all of the IP systems and datamine to a separate controller. The veralite worked good before I put the alarm system, hue bulbs, AV receivers, and of course datamine on it. Now it’s just about out of magic smoke.
glad not just me then - i have quite a few IP based tasks so thought it may make sense but don’t really know how they will play together. if its really not needed then ill be happy not to use the vera2.
I’m always having to prioritize and remove plugins on the vera2
Well it is a VERA 2… You were over due for a hardware upgrade years ago. If things even ran on a 2 you should need a PLUS and a two running similer tasks. Just put it all on one.
