Vera Edge filter/grep the log files?
Is there some info about the logfile? I tried to tail -f it, but that gives a lot of lines.
Sometimes I only want to know if a signal is getting into the Edge, a scene is started etc.
I saw the lines begin with 04, 06 for example. But is there some info about this?
You can use tail -f /tmp/log/cmh/LuaUPnP.log
and you can also grep for specifics using tail -f /tmp/log/cmh/LuaUPnP.log | grep -i ‘device: 23’
Let me know if this helps.
Possibly useful info here: [url=http://wiki.micasaverde.com/index.php/Luup_Debugging]http://wiki.micasaverde.com/index.php/Luup_Debugging[/url]. Several plugins also available to help.
Great. Thanks. Exactly what I was looking for.
