Vera Edge & Fibaro 3 in 1 sensor - dead and still alive
Hello,
I installed an Fibaro 3 in 1 sensor. Everything worked fine and I got an SMS every time it detected a movement.
But than I decided not to use it anymore. The sensor is now lying since 3 weeks in his original box, without a battery installed.
The Vera Edge “successfully” can not detect the device anymore and shows me one error in the dashboard. So far so good.
But 1 or 2 times a day I get a “movement detected” SMS as if the device would be active. Even this doesn’t bother me too much because I could simply remove the device until the day I have a new usecase.
But how reliable is Vera Edge in combination with this device? If it detects movements 10 times a day or just once, how can I be sure it really was a movement? Originally I wanted to fire my internal and external sirens with the 3 in 1 sensor as trigger.
Does anybody has ever had issues like that?
