Vera Edge continue to restart and backup zwave
Hello.
I bought Vera Edge to replace a overloaded veralite.
After restore the veralite backup in the Edge I’ve noticed that a lot of things did not going well so I decide to make a clean installation, I reset vera edge to factory and I had re installed all zwave devices.
Now I have this:
All devices are working BUT they are not always showing the real status of present condition (if they are ON or OFF).
I think because vera is continuing startup and probabily does not report correctly the status of my temperature sensors or the positions of my windows blind.
Also VERAALERT plugin continue to report “vera startup” at least once every 2 minuts
And if I made some changes of the values in the Device Param. window, vera report “Change property command sent” of course I save the change by the button but then if I reload the page the value is still the old one…
Unfortunally I do not know LUA so i’m stuck. In the attacchement the log error via ssh but what it sound strange to my eyes is the call to ip 192.168.0.113 that is my google chromecast that I never try to connect to vera…
Somebody can suggest me something to do (except the hammer;) )
I opened a ticket with the support last week …but I’m still waiting.
Thank you in advance.
David
The call to your Chromcast is UPnP scanning. Disable network scanning on Vera and it should stop.
When you restored your Vera Lite backup, was the Vera Lite running UI7? Migration restores need to be to the same UI version.
Also note that the edge has a completely different zwave chip than the Vera Lite. You can not simply restore the zwave chip onto the Vera edge from your vera lite.
  • Garrett
