Vera Edge 7.31 suddenly luup reloads
As I reported, in my case it was just updating two variables (color and brightness) for three devices at once. Given the fact that I was running the code with parallelism, and only at night, it was easy for me to catch it.
Moving all the calls from my system to a queue helped a lot. I now have from 2 to 10 days of luup uptime. Unless, out of the blue, it starts to reboot every 20 minutes or a child is corrupted or…
The new fw is too new to be considered at the moment, so we should live with this one, unless we want to move to a different solution. During the last year I wrote so many defensive code to just circumvent odd behaviors…
Yup, we’re all in that boat together. Hopefully we don’t lose the bilge pump.
After puzzling over them for a couple of months, my unexpected Vera restarts now seem to be centered around one particular Reactor routine (called “Lights Out”) that systematically turns off 10+ lights in rapid succession (i.e. no pauses between).
Although the restarts don’t happen every time the routine runs, my theory was that they resulted from the quantity or speed of commands being sent. But then I remembered something…
…my “Lights Out” Reactor routine also included a couple of devices that had been taken offline (unplugged, but not unpaired from Vera) long ago. I had forgotten to remove them, and because Reactor didn’t issue any warnings in this regard, they remained part of the routine (by far, the longest of all my Reactor scenes).
Until today. Following yet another unexpected LUUP restart last night, I went ahead and groomed “Lights Out” by deleting the offline devices. I’ll carefully monitor whether Vera restarts the next few nights, and if she does, I’ll introduce 1-2 second pauses between commands and see if things finally settle.
That may be an aggravation, you’re correct. My “away” routine at night used to turn off all lights (20+) and close all roller shutters (10), unless I divided it into smaller routines. Previously, the chances of a luup reload were very high, after removing the roller shutters it started to behave better. Long story short, dead device may increase the command queue and cause deadlocks, that in Vera’s land equals to a luup reload. As I said, I have this and many more defensive code/actions in place in my controller, but this should not be the case for a stable system… but the current fw generation clearly is not.
Mongoose related crashes are starting to happen daily. No changes to the system in several months. The worst part is they are happening right after I set my alarm to away state - so the things I need it to do when I leave home are not completing. I stabilized these routines under UI5 5+ years ago, and then again on UI7 3 years ago.
Nothing to go on in the logs (regular log levels). This time it was
Reload: Downloaded Plugin Critical
Quit_set now 1 for 0x15c6750 ThreadedClass::StopThread
Mongoose XXX-mg_stop1
LuaUPnP Terminated with Exit Code: 0e
Based on this might be time to disable auto update on all my plug-ins. Dang I love/hate Vera.
I disabled it a year ago and never looked back. I usually have from 2 to 10 days of luup uptime, but I had to optimize every single bit of it.
Slightly tangential, but may help
I have (had) a scene that runs at night to turn of all the lights, set the thermostats etc etc. About 15 devices plus some virtual and a couple of TTS.
Triggered by Alexa and another virtual switch or a key press.
Native scene this probably failed to run at all about 20% of the time. Then it would always say ‘not responding’ then it would finish (probably 20 seconds after the ‘not responding’)
I moved it to Reactor yesterday. Finished instantly. Even with additional witty comments via TTS
Might be worth considering replacing Night Mode with a Reactor?
C
Chiming in as another user having this issue. @Sorin - I actually have a ticket in with support for the past month or so. Their conclusion was my Nest/WWN plugin (I’m still holding on converting my Nest IDs to Google!).
I have my doubts. I see the Mongoose crashes and mine also appears to be related to Zwave and/or Reactor events (not blaming Reactor - probably something Reactor is telling Vera to do). However, I’ve been unable to correlate my reboots/reloads to any one event.
Frustrating.
I did have a few battery devices that needed to have their batteries replaced (a fob and motion). I did that last night. We’ll see if that helps.
Bumping the tech team. They will be with you shortly. :vulcan_salute:
“luvd_restart_mongoose” again yesterday. Anyone made any progress on figuring out the reason and how to prevent?
‘Mongoose’ (which I believe is a lightweight web browser built into Linux) has been a problem plaguing Vera users for many years. I seriously doubt any ‘fix’ is in the pipeline.
Here’s a 2016 reference to similar unwanted restarts, which include sa mention of ‘Mongoose’:
I have similar problems and I was promised it will be fixed, but now I think luup engine is basically dead and it has not been in their radar anymore.
My ticket has been with senior engineers for a few weeks now. I’m patiently hoping for a fix. I don’t have just reloads (those are almost acceptable) but I’m also having full OS reboots. Argh!
Well patience is a virtue.
I’m going quite the other way
C
