Vera changes GC100 IP
I have a vera 3 and have setup a wifiir itach.
All work fine but after a while of inactivity vera forgets what the ip of the ir is and I have to go in and correct it.
Period of time could be from 2 hours to 2 days or doesn’t have a pattern.
Any suggestions would be welcomed thanks :).
Try this…
http://forum.micasaverde.com/index.php/topic,4040.msg20995.html#msg20995
Thanks for reply,No issues connecting to vera, I’ve already set static ips.
Issue is that vera forgets what up the gc100 is.
You miss the point … You need to setup a static IP for your GC100.
Vera has static.
Gc100 has static.
Gc100 is a device in the vera, in the device options there is an ip for the gc100, after a period of time this ip changes in the uiandomly and then I can no longer talk from vera to gc100 untill I re input the correct ip into the vera ui.
Note the ip of the devices don’t change the ui just forgets what ip it is.
