Quite frustrated here… I have had success with:
3 Wayne-Dalton thermostats
1 light switch and
2 dimmers
3 sections with 6 rooms, uncomplicated scenes.
Adding 2 HSM 100 sensors was too much to ask so I took them out of the devices mix.
Two successful days of 4 am chron reboots, I felt really confident this was going to help me manage my life while away. Blech… Yesterday, I noticed the reboot happened at 5 am instead and the usual 9 pm “vera is down” occurred at 8 pm.
Mmmm…
Ghosting devices wouldn’t go away (I read, I reset the devices, deleted, removed dead nodes… rebooted, double tapped black button to reset – I tried everything in the book), so I created a “dead devices room” and assigned them there out of my way.
Last evening, after starting from scratch again, I was able to connect locally, remotely, and FINALLY got everything to harmonise. Then I goofed. I upgraded from 1.0.918 to the lastest:
1.0.939
I lost remote and local access. That was last night. Brand new day today.
I connected vera direct to my laptop (L1) in hopes of accessing 192.168.xxx xxx. The goal was to plug vera back in and reset this afternoon.
The lights on the front of the unit are flashing (4 times per second). Nothing is solid or even “thinking.”
I do appreciate what the MCV team is developing, but anything in Beta should not be advertised as ready for prime time. I don’t mind being a test subject as long as I know that’s what I’m buying into. I knew “works out of the box” was not going to be that way. Nothing is that easy. I simply didn’t expect living with this to be a(nother) full-time job.
Patience is getting veeeeeerrrry thin around here. Which direction am I supposed to go in now?
Cobette
edit: corrected 193. to 192… adding: Wish I could restore from the backup I made. The box is there; nobody’s home…
