CMRancho,
I found your trouble ticket by matching the email address from the forum with the ticket system. I picked one node, node #9 device ID #4, “Kitchen”, ZWaveDimmableLight to see what’s wrong. I can tell you for 100% certainty the problem with configuration has nothing to do with the Luup upgrade–it’s something in the Z-Wave chip or the Z-Wave network, not with Vera. This is probably too technical than you care to know, but here’s the actual log of the data coming to/from the Z-Wave chip in the black dongle:
41 08/28/09 14:25:20.227 0x1 0x4 0x0 0x60 0x9 0x92 (#####) <0xc04> 42 08/28/09 14:25:20.237 0x6 0x1 0x4 0x1 0x60 0x1 0x9b (####
##) <0x1406>
42 08/28/09 14:25:20.238 got expected ACK <0x1406>
41 08/28/09 14:25:20.240 ACK: 0x6 (#) <0x1406>
42 08/28/09 14:25:21.617 0x1 0x6 0x0 0x49 0x81 0x0 0x0 0x31 (###I###1) <0x1406>
41 08/28/09 14:25:21.619 ACK: 0x6 (#) <0x1406>
The ‘0x60 0x9’ is Vera asking the Z-Wave chip to fetch the status of node #9. The ‘0x49 0x81’ is the Z-Wave chip’s response. The result code 0x81 is defined by Zensys as: UPDATE_STATE_NODE_INFO_REQ_FAILED
So I know for sure it’s not an issue with Vera’s software or hardware, because Vera is talking to the Z-Wave chip just fine, and the chip is responding that node #9 is non-responsive. Actually all your nodes are doing this. Now I see that at: 08/25/09 19:34:51.087 you were running 616. And at that time, you had 8 nodes in your system: 2, 5, 6, 7, 8, 9, 11, 12. Then I don’t see any activity on 8/26, and on 8/27 when Vera came back online with Luup 862, the dongle reports only 2 nodes: 9 and 13. You subsequently added more nodes and now have 9, 13, 14, 15, 16, 17, and 18.
So that means, as far as I can tell, when you upgraded to Luup you also changed something in the dongle itself. You either swapped dongles, or did a dongle reset, or removed and repaired devices or something, presumably on 8/26 when Vera was down. Can you shed some light on what happened at that time?
