Part of the reason I purchased Vera was to use it as a proxy for UPnP devices with a simple HTTP interface. The paragraph on “UPNP aggregation & secure remote control” in the Luup press release claims that Vera will present existing UPnP devices over a secure gateway so I was assuming that the HTTP request interface would be available for them:
Thanks for the links…definitely helpful info. At this point, though, my issue isn’t really Sonos related. It really applies to any UPnP device that you add to Vera. I was hoping I would be able to control the device via Vera’s HTTP interface but based on the “No Control URLs” error, that does not seem to be the case…unless it’s just a configuration issue?
