Vera as master controller and a S2 stick as seccondary
Hello,
I was trying yesterday to add a Z-stick s2 as secondary controller to a vera lite 3 but I couldn’t add it either self-powered with full power inclusion on vera nor with the so old Z-Tool…
Then I tried the shift, but seeing it was copying I stopped it on the receiver side, then saw everything has disappeared in the vera network, then I tried to restore from a backup but none came back, then I reincluded every device and they weren’t included, so I included them directly…
Well from that, what would you recommend me to do ? make the Z-Stick primary then shift again to Vera (if it is possible ??? how can I sync back the vera with the stick afterward ? ? ? )
Thanks,
Emmanuel
I am sailing in the same boat. Couldn’t figure how to set z-stick as secondary controller. Hoping to see a solution here.
Abhinav
