Hi all,
I had asked questions regarding the configuration of the QEES Ring (a EU Z-wave mini remote with 4 buttons) and Vera.
I finally found a way to configure it: after creating a scene related to a “scene activation” (nr 1 to 4), Vera tries to update the Qees Ring, I launch the learn mode on the Ring (short + long press on config button), and all is set.
The problem is that this only works for “ON” orders…but the Ring has 4 ON/OFF buttons. I have of course tried to create scenes where the event is linked to “a scene is deactivated”, but this never works (no command seems to be received).
Now I am suspecting that the Ring shouldn’t be considered by Vera as a “scene controller” (which I am guessing only has “ON” buttons for X numbers of scenes), but rather as a regular remote.
The device type (auto configured by Vera) is for now: urn:schemas-micasaverde-com:device:SceneController:1
Is there any way I can configure the device to be configured as a device so that OFF orders also trigger scenes?
I am on UI4, and found an online manual (based on UI2) that says I should select the “Treat scene buttons as events” option… maybe this option is the key to my problem, but it’s not there in UI4 (nor was it in UI3).
Any help is welcome! I am attaching the detailed config of the ring
