I know this is an old thread but I wanted to say thanks, the the tips in the thread helped me get my homebridge up and running very well. Seems like even the flood sensor is working without having to input the http codes. Believe it or not, I even have my TRANE thermostats working through the nexia plugin. I get a warning that it slows it down but I don’t notice it in practice. Thanks for you guy’s efforts!
Hello, I have today updated Homebridge to 1.3 version and Vera plugin:
works, but it generates these errors:
[15/03/2021, 10:17:48] [Hue] Digestoř 2: set homekit transition control to ""
[Osvětlenost koupelna@Osvětlenost koupelna@Current Ambient Light Level] characteristic was supplied illegal value: number 0 exceeded minimum of 0.0001
[15/03/2021, 10:17:48] [homebridge-vera] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic was supplied illegal value: number 0 exceeded minimum of 0.0001. See https://git.io/JtMGR for more info.
[EZS poplach@EZS poplach@Battery Level] characteristic value expected valid finite number and received "NaN" (number)
[15/03/2021, 10:17:48] [homebridge-vera] This plugin generated a warning from the characteristic 'Battery Level': characteristic value expected valid finite number and received "NaN" (number). See https://git.io/JtMGR for more info.
[EZS aktivní@EZS aktivní@Battery Level] characteristic value expected valid finite number and received "NaN" (number)
[15/03/2021, 10:17:49] [homebridge-vera] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic was supplied illegal value: number 0 exceeded minimum of 0.0001. See https://git.io/JtMGR for more info.
[15/03/2021, 10:17:50] [homebridge-vera] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic was supplied illegal value: number 0 exceeded minimum of 0.0001. See https://git.io/JtMGR for more info.
[15/03/2021, 10:17:51] [homebridge-vera] This plugin generated a warning from the characteristic 'Current Ambient Light Level': characteristic was supplied illegal value: number 0 exceeded minimum of 0.0001. See https://git.io/JtMGR for more info.
I suppose it is because the plugin for Vera had not been updated to match 1.3 Homebridge criteria, is it problem to leave it like that? I suppose there will be not update to Vera plugin…
It seams that since 1.3 Homebridge version they control value types and characteristics and if it is not regarding the rules, it corrects the value and sends this warning. I have contacted the developer via Message here in forum, I really love it, because it made possible to controll all my devices in Vera from HK.
How are you dealing with these warnings? Are you ignoring them?¨
Thanks!
Good morning,
Homekit compatibility has been requested as a feature in the new platform and it’s pending for approval. Here is the case.
Regards,
Thanks, but that is future and new platform, I use current Vera unit
Good morning,
For legacy units the next firmware upgrade will be the 7.32 version. We will be maintaining support for the platform. After this version, we’ll be making maintenance upgrades on an as-needed basis to ensure full functionality. However, we won´t be completing feature request of this nature.
Regards,
