Vera and findvera.com Users
If I set up a second user on my Vera with “Full access to the system” will/should that user be able to log in to findvera.com?
I want to set up my wife with her own log in so that she can unlock the door from her BlackBerry.
Just try it and see for yourself - findvera.com allows only one login, which is called “home” login.
User logins are separate and I believe work on top of “home” login in findvera.com, when you click “Control”…
Not sure how it works in Blackberry app, though.
I have my wife set up as a unique user. Her user name and password cannot be used to access the findvera.com Is that by design? Should the main user be set up as commom user so that all people I want to give access via MO or the java app can use that common user?
Nevermind. I reread the Users entry in the wiki. If I read it correctly this time, only one user logon is allowed per Vera through findvera.com.
Correct. The ‘local’ users you create on the users tab are unrelated to the single ‘findvera’ user account. Local users are there whether you use the findvera service or not. They’re local to your Vera, and not stored on our servers. The ‘findvera’ user account is for for remote access.
