I have a wall mounted tablet that is near a motion sensor I have in Vera.
My goal is if the motion sensor is armed (tripped) wake the tablet screen up.
I am getting a little confused at what needs to do what and in testing been unsuccessful in everything I have tried.
So my first questions would be…
Does this seem doable? With tasker it seems possible.
Do I need AutoRemote or will Vera Alerts Vera and Android app suffice?
Just using vera alerts android and vera app I have configured the profile vera-alerts-lan.
I entered my tablet IP and the same port I configured on the app.
When I send a message this is what I see in my Lua log:
Ok so I removed all of the auto* pluggins.
I was able to send a test message to my tablet and saw it!
So now it sounds like I need too:
Create a new notification user (done)
Configure a notification and profile within the Vera Alerts vera app.
I am stuck here. I create the new user.
Login as the new user. Within Vera AND the VeraAlerts app I dont see my new user.
I created the user with a fake email if that matters. I thought it was local so it didnt.
Well I didnt figure out the user thing but I was able to create the new Profile and use that in a scene from the motion detector.
It works great. I will add some LUA to add some conditions but so far great. I will trial this for a few days than you will have my money!
Like anything Vera it seems like the potentials are unlimited it you have enough time to play.
Thanks I will.
I spoke to soon.
Vera Alerts in Vera to Vera Alerts in Android is happening as expected.
Tasker has chosen to not do anything with them.
I got frustrated last night but tonight I will see if I can work it out in tasker.
Well I have found an issue with tasker\vera_alerts.
When you use tasker ‘state’ context to select the alert message from vera alerts it stays active.
I haven’t found a ‘good’ way to clear the state from tasker.
My complete setup:
In vera:
In a scene I want to run a vera alert I add luup:
luup.call_action(“urn:richardgreen:serviceId:VeraAlert1”, “SendAlert”, {Message=“TabletOn”, Recipients = “KitTab”}, 25)
I have vera alerts and tasker running on my tablet.
My tasker profile is:
Profile “TabletOn”: State → Vera Alerts → TabletOn; Run Task “Wake Screen”
Task “Wake Screen”:
Popup → Alert → Popup → “The current time is %TIME”
Wait → Task → Wait 1 minute
Profile Status → Tasker → Profile Status → “TabletOn” → Turn Off
Profile Status → Tasker → Profile Status → “TabletOn” → Turn On
I found that waiting > 30 seconds and cycling the tasker profile allows the state to turn back off. It does cause 1 extra popup which is mildly annoying.
