Vera Alerts not working WiFi mode
Vera Alerts seem to stop working today literally mid sentence. This was on my phone. I’ve re-installed and rebooted many times but still doesn’t work. I tried sending to my kindle fire and nothing there either. Later it started to work again on the Fire but not on the my phone. Now it’s back to neither working.
I’m only using wifi and unregistered vera alerts. I’ve checked and double checked the setup info on the android clients and my IP address and port I’m sending the alerts to match what vera is using.
Any ideas?
Edit: LanServices and sometimes TTSServices appear to be running on the phone as a vera service. Not sure if anything should be running.
Did you try rebooting your phone.
[quote=“mike Q, post:1, topic:176544”]Vera Alerts seem to stop working today literally mid sentence. This was on my phone. I’ve re-installed and rebooted many times but still doesn’t work. I tried sending to my kindle fire and nothing there either. Later it started to work again on the Fire but not on the my phone. Now it’s back to neither working.
Any ideas?
Edit: LanServices and sometimes TTSServices appear to be running on the phone as a vera service. Not sure if anything should be running.[/quote]
Yes, mentioned above. Oddly, this morning out of the blue, it’s working on the Fire but still not on the phone.
Something odd is going on. All this time that the phone has not been working, it didn’t display the little Vera Alerts house icon in the top bar.
I just went into wifi settings to verify the IP Address on the phone was getting the static ip setup for it by the router. When I exited out of the setup screen, the Vera Alerts icon on the status bar was there and now the phone is working.
Is that icon and indication that the service that scans the lan for messages is running? The LanService for vera has been showing up when I look at running services all along but the icon has never appeared.
I am having issue also with my Vera Alerts. My Vera 3 is connected with WiFi but I’m using registered version with the id. It was working till 2 am last night. (well last time i had a alert)
But i was messing about with ports on my router, so maybe, i have directed a port away that is required? don’t know if this information will help you at all.
Also, I have only just set all this up, so i don’t know much about it. but will let you know if i find reason mine has stopped.
i uninstalled then re installed the app and it is working now
The Vera Alert Icons is display when a notification is delivered to the phone.
It stays there until you notice the Notification … i.e. you open the Vera Alerts App.
Seems like the phone’s wifi is sleeping but it does give any indication on the wifi icon. I have a “stay awake” app running that is supposed to prevent wifi from shutting down but for some reason it doesn’t seem to be working.
When I can no longer get alerts, I can go into wifi settings and back out to the main screen. Once I do this I will start getting alerts again but eventually I lose them again.
In the APP I request that the WIFI be left on …
What version of Android are you running ?
Your version, or device, may not support that feature.
I’m running a 2.2.3 phone.
As a note, I have the same issue. Wifi alerts don’t work. I reboot the device and they work for a bit, but eventually they stop and I have to reboot the tablet again (Asus Transformer TF101 with Android 4.0.3).
I finally gave up and went with the google style alerts because they seem to happen faster, though I’ve noticed recently they are also being delayed (up to five minutes). I’m thinking that is more on Google’s side though. They do always go through though!
I think I have thing working reliably now. The wifi sleep policy was set to “stay active while chargine” or something like that. For some reason, this means “randomly go to sleep”. Setting it to “never” and using my “stay awake” app seems to have me running okay.
SirMeili, try going into your wifi setting when alerts stop working and reconnect to the network. If they work after this, I suspect your wifi connection is shutting down due to some policy setting like mine.
Mike,
I am having the same issue, but with a later version of Android (Jellybean). I also have the WiFi keep alive app, but I’ll have to try to set the device’s setting to ‘never’ and just have the app override it. I’ll try this when I get home. Thanks!
