Vera 3 UI 7 cannot pair Kiwkset 910
I finally got around to installing the Kwikset 910 that I got a few weeks back. I was able to get it installed and set a PIN manually. Then I went to pair it to my Vera 3 but it just doesnt seem to work. I even moved the Vera 3 to with in 3 feet of the lock and its still not working.
I have followed the steps here: http://wiki.micasaverde.com/index.php/Kwikset_Lock with the same results.
When I press the upper left button on the lock a red light comes on and there seems to also be an amber light that comes on too. About 5 seconds later the amber light goes out but the red stays on for about 5 more seconds then it does dark. I have removed the 2 screws that hold in the zwave daughter board and then removed that board, reseated it and followed the steps again. Do I have a defective unit? Is there anything else I can try?
Apparently the lock I had was defective. I picked up another one today and swapped out just the inside part and once it powered up I was able to pair it right away.
