When I edit devices (e.g. rename a newly added device), and press SAVE, I receive this message:
Save data
This feature is not enabled. You need to upgrade to the ‘Professional Home Automation’ option.
What are you asking me to upgrade too, to have basic naming functionality?
Please just click on the link and select Vera 3. It will find your Vera 3 and tell it to download the new firmware. It does not matter if Vera is your main router or just a client on your network. As long as it can get an internet connection, the firmware page will work.
I am having the exact same issue as described above. It just started happening today. I am running firmware 1.5.346 and already tried the remedy that was given. What else should I do?
Update: I unplugged, waited, restarted and it seems to have resolved the saving issue. One switch is still iffy.
“Save data
This feature is not enabled. You need to upgrade to the ‘Professional Home Automation’ option.”
I just started having this same problem this morning.
Firmware 1.5.622
Serial 30005010 - (I think that is it)
One of the light switches just stopped responding a week or so ago and I went to look at it this morning and now I can’t even save a change to a schedule.
