I recently had the wifi on my Vera 3 at a vacation home go out and would not connect with a wireless VistaCam. The other Vera functions worked fine. When I got back on site the wifi was not connecting to anything, ipad, iphone laptop, etc. A power on/off restart of Vera 3 fixed it. Is there a way to send a remote command to Vera 3 to do a restart on its own, or do I do like some others I’ve read and just run the Vera off a timer and let it restart every 24 hours?
Remote Vera commands reach Vera via the internet. If Vera’s internet connection(seemingly WiFi in your case) is interrupted then no commands can reach it.
Vera is connected to internet by wire. Wifi is used for connecting wireless cameras.
You could ping the cameras address using the ping plugin, and then use this as a trigger to use os.execute( ‘reboot’ ) in a luup scene if the connection goes down.
There is some risk to the above since maybe the camera dies, or doesn’t respond.
Then log on to cp.mios.com and click Setup → Net & Wifi → Reboot
