Frustration. I haven’t accessed the device in some time. and now when I need to I can’t… any suggestions ? Port 80 access is a no go. I have power cycled the box with the same results.
Try this log in via cpui5.mios.com.
It should present you with the unit and the last ip address it registered.
Close the browser and they to access locally using the ip address identifies above.
Does this work?
If not what message is received?
If it isn’t still work please provide details of how your unit is connected locally e.g what port ethernet or wifi etc.
